Date/Time: Mon, 20 May 2024 11:02:01 +0000
Calculating average 30min bar ranges
View Count: 63
[2024-04-26 20:29:18] |
User274507 - Posts: 37 |
Hi, I found that the numbers bar calculate bars can tell me the range of each 30min bar, but is there any way Sierra can then tell me the average of these for a session? So I want the range of each 30min bar for a session added and then divided by the total number of bars. And is there a way to download statistics like that from a market profile? thanks |
[2024-04-26 20:47:50] |
John - SC Support - Posts: 31734 |
There is a study called "Average True Range" that does most of what you want. Refer to the following: Average True Range The only thing it does not do is give the average for a session. To do this, you would have to use the Spreadsheet Study to grab the data from a specific time (start of session) and then update as new bars are added. Refer to the following: Using the Spreadsheet Study With regards to the TPO Profile (Market Profile) refer to the following for what information is available: Time Price Opportunity (TPO) Profile Charts: TPO Profile Text Information Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
