Date/Time: Sun, 19 May 2024 02:03:09 +0000
[Sticky] [Locked] - Reduced Listing of $ Barchart Index Symbols
View Count: 697
[2024-04-18 23:12:59] |
Sierra_Chart Engineering - Posts: 14423 |
To reduce clutter, reduce maintenance, and increase performance of Symbol Settings, we have removed the majority of index symbols in Sierra Chart that start with a $, from being listed in File >> Find Symbol. We have only listed the most common ones in use now. They are in File >> Find Symbol >> Cash Indexes (Non-Realtime) Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You can still use all of the available symbols and find the listings here: http://datasrv.ddfplus.com/names/ They are in the index_*.txt files. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-04-18 23:14:11
