Date/Time: Mon, 20 May 2024 08:27:26 +0000
Remove/Hide Current Traded Ask & Bid Volume Text - DOM
View Count: 876
[2022-10-28 05:38:50] |
DayTraderEsad - Posts: 116 |
Is it possible to add a option where you can remove the text from the current traded Bid & Ask Volume for the DOM and just have the Volume bars? I have attached a pic of the DOM and highlighted the area that I am asking about. Thanks for your help. |
Screen Shot 10-27-2022 at 10.36 PM.png / V - Attached On 2022-10-28 05:36:36 UTC - Size: 45.6 KB - 166 views |
[2022-10-28 14:39:21] |
John - SC Support - Posts: 31734 |
This option does not exist at this time. The best you could do is to set the text for that column to use the same color as the background, but then when the volume bars display into the text, you will see that portion of the number displayed. We have set this as a Feature Request. Just keep in mind that we do not know when, or if, we will get to any particular feature. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-08 14:53:07] |
sean3000 - Posts: 37 |
+1
[2023-03-08 16:18:29] |
This is available now. Refer to the following: Chart Settings: Hide Volume Numbers From Current Traded Volume Columns (Chart >> Chart Settings >> Display >> Chart Display Items menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-04-12 23:12:01] |
@TRADE_YOUR_PLAN - Posts: 126 |
It would be great if we could have the same thing with recent bid/ask volume in chart or trade DOM columns.
[2024-04-12 23:16:19] |
drod93 - Posts: 3 |
+1
[2024-04-12 23:18:35] |
DLee - Posts: 3 |
+1
[2024-04-12 23:19:00] |
Optionyout - Posts: 7 |
This would be great. The numbers are nearly illegible anyway unless you are zoomed way in. The bars tell the story.
[2024-04-12 23:53:41] |
GARYtheG - Posts: 2 |
+1
[2024-04-13 01:04:42] |
LeDork - Posts: 19 |
Agreed, this would be great. +1
[2024-04-13 03:46:21] |
Juuaan - Posts: 1 |
+1 Thanks!
[2024-04-13 05:23:19] |
tradingnoob - Posts: 1 |
+1 thanks
[2024-04-13 13:54:04] |
barucho - Posts: 3 |
+1 Thanks
[2024-04-13 14:37:25] |
User559818 - Posts: 2 |
+1 thanks
[2024-04-14 13:25:58] |
JDN2K - Posts: 2 |
+1 Thank you!
[2024-04-15 14:13:13] |
User38682 - Posts: 18 |
+1
[2024-04-23 21:41:18] |
christostrades - Posts: 8 |
+1
[2024-04-26 20:09:25] |
AlexRSchultz - Posts: 1 |
+1
[2024-05-06 17:19:59] |
mandano89 - Posts: 12 |
+1
