Date/Time: Mon, 13 May 2024 08:24:06 +0000
[User Discussion] - Python SCID to TSV / CSV and Pandas DataFrame Conversion
View Count: 7331
[2013-04-20 23:05:04] |
Kiwi - Posts: 375 |
User Discussion (Free Code) This post describes code to convert scid files to tsv (tab separated variable, but you could easily change to comma separated (name and delimiter)). SCID Format This code can be used to create a Python Pandas DateTime indexed Dataframe. Use at your pleasure and risk - If you modify it or improve it, a post of the changes would be appreciated. def getRecords(filename, tzadj):
""" Read in records from SierraChart .scid data filename Output a list of DateTimes and list of rows """ def deserialize(date_and_time): date_tok = int(date_and_time) time_tok = round(86400*(date_and_time - date_tok)) d = date(1899, 12, 30) + timedelta(date_tok) t = time(*helper(time_tok, (24, 60, 60, 1000000))) return datetime.combine(d, t) def helper(factor, units): factor /= 86399.99 result = list() for unit in units: value, factor = divmod(factor * unit, 1) result.append(int(value)) result[3] = int(0) return result sizeHeader = 0x38 sizeRecord = 0x28 if tzadj == 99999: tzAdjust = datetime.fromtimestamp(0) - datetime.utcfromtimestamp(0) else: tzAdjust = timedelta(hours=tzadj) with open(filename, 'rb') as fscid: fscid.read(sizeHeader) # discard header rows = [] ix = [] for i in xrange(1000000): data = fscid.read(sizeRecord) if data != "": d = struct.unpack('d4f4I', data) datarow = [d[1], d[2], d[3], d[4], d[5], d[6]] rows.append(datarow) ix.append(deserialize(d[0] + tzAdjust.seconds/86400.0)) else: break return (rows, ix) def getDataFrame(filename, tzadj): data, ix = getRecords(filename, tzadj) return pd.DataFrame(data, index=ix, columns=['O', 'H', 'L', 'C', 'V', 'T']) if __name__ == '__main__': """ Takes a SierraChart scid file (input argument 1) and converts it to a tab separated file (tsv) Timezone conversion can follow the users local timezone, or a specified integer (input l or an integer but if the default filename is being used, '' must be specified for the filename) """ filename = '/home/john/zRamdisk/SierraChart/Data/HSI-201303-HKFE-TD.scid' tzvar = 0 if len(sys.argv) > 1: if len(sys.argv[1]): filename = sys.argv[1] if len(sys.argv) > 2 and len(sys.argv[2]): print sys.argv[2], type(sys.argv[2]) if sys.argv[2] == 'l': tzvar = 99999 print tzvar, type(tzvar) else: tzvar = float(sys.argv[2]) print tzvar, type(tzvar) tzvar = 99999 df = getDataFrame(filename, tzvar) print df[0:10] print 'fin' Date Time Of Last Edit: 2013-04-21 03:51:24
[2013-04-22 00:20:17] |
Kiwi - Posts: 375 |
This is a modified version of the TSV code that adds the option to use a different datetime format: """ Returns excel date time in format YYYYMMDD HHMMSS """ import csv
import re import sys import numpy as np import struct from time import ctime from datetime import date, datetime, time, timedelta # import ipdb # import ipdb; ipdb.set_trace(); ## *** ## def deserialize(excelDateAndTime): """ Returns excel date time as Python datetime object """ date_tok = int(excelDateAndTime) time_tok = round(86400*(excelDateAndTime - date_tok)) d = date(1899, 12, 31) + timedelta(date_tok) t = time(*helper(time_tok, (24, 60, 60, 1000000))) return datetime.combine(d, t) def helper(factor, units): factor /= 86399.99 result = list() for unit in units: value, factor = divmod(factor * unit, 1) result.append(int(value)) result[3] = int(0) return result def datetimeTwo(excelDateAndTime, tzAdjust): """ Returns excel date time in format YYYYMMDD HHMMSS """ t = str(deserialize(excelDateAndTime + tzAdjust.seconds/86400.0)) return (re.sub(r'(:|-)', '', t)[:8], re.sub(r'(:|-)', '', t)[9:15]) def excelTimeAdjust(date_and_time, tzAdjust): return date_and_time + tzAdjust.seconds/86400.0 def getRecords(filename, fileoutput, tzvar, dtformat): """ Read in records from SierraChart .scid data filename dtformat determines the datetime representation in column 1 (and 2) """ sizeHeader = 0x38 sizeRecord = 0x28 if tzvar == 99999: tzAdjust = datetime.fromtimestamp(0) - datetime.utcfromtimestamp(0) else: tzAdjust = timedelta(hours=tzvar) header = ('Date', 'Time', 'O', 'H', 'L', 'C', 'V', 'T') ftsv = open(fileoutput, 'w') fileout = csv.writer(ftsv, delimiter='\t') with open(filename, 'rb') as fscid: fscid.read(sizeHeader) # discard header fileout.writerow(header) for i in xrange(300000): data = fscid.read(sizeRecord) if data != "": dataRow = struct.unpack('d4f4I', data) if dtformat == 0: adjustedTime = dataRow[0] + tzAdjust.seconds/86400.0 outrow = (str(adjustedTime), str(adjustedTime), str(dataRow[1]), str(dataRow[2]), str(dataRow[3]), str(dataRow[4]), str(dataRow[5]), str(dataRow[6])) fileout.writerow(outrow) elif dtformat == 1: date, time = datetimeTwo(dataRow[0], tzAdjust) outrow = (date, time, str(dataRow[1]), str(dataRow[2]), str(dataRow[3]), str(dataRow[4]), str(dataRow[5]), str(dataRow[6])) fileout.writerow(outrow) else: break return if __name__ == '__main__': """ Takes a SierraChart scid file (input argument 1) and converts it to a tab separated file (tsv) Timezone conversion can follow the users local timezone, or a specified integer (input l or an integer but if the default filename is being used, '' must be specified for the filename) """ filename = '/home/john/zRamdisk/SierraChart/Data/HSI-201303-HKFE-TD.scid' tzvar = 0 if len(sys.argv) > 1: if len(sys.argv[1]): filename = sys.argv[1] if len(sys.argv) > 2 and len(sys.argv[2]): print sys.argv[2], type(sys.argv[2]) if sys.argv[2] == 'l': tzvar = 99999 print tzvar, type(tzvar) else: tzvar = float(sys.argv[2]) print tzvar, type(tzvar) fileoutput = filename[:-4] + 'tsv' getRecords(filename, fileoutput, tzvar, 1) |
