Date/Time: Mon, 29 Apr 2024 10:26:56 +0000
[Locked] - Notice: New Market Statistics Data Feed
View Count: 9751
[2014-02-21 18:54:59] |
Cavalry3162 - Posts: 523 |
I can confirm that the issue has been resolved and the Stats are updating. Thank you for your quick Resolution! Andreas Edit: i am on cqg Date Time Of Last Edit: 2014-02-21 19:27:46
[2014-02-21 19:11:21] |
maxima120 - Posts: 144 |
yeah it is working now (rithmic service)
[2014-02-21 19:13:13] |
Marmany - Posts: 303 |
Situation not yet resolved here. Primary Service is TransAct. Niss - NYSE, - Nasdaq & TF show no data on an intraday chart Niss - NQ & SP only show data to close on 19th Feb The old symbol $NSF only shows data up to 20th Feb. For info I update from SC 1084 to 1094 this morning |
[2014-02-21 20:19:00] |
Handle - Posts: 36 |
TransAct Not working |
[2014-02-21 20:26:55] |
TransAct What does this mean? Make sure you are on the latest Sierra Chart version if you are referring to market statistics.
Not working Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-21 20:32:36] |
Niss - NYSE, - Nasdaq & TF show no data on an intraday chart Niss - NQ & SP only show data to close on 19th Feb The old symbol $NSF only shows data up to 20th Feb. Update the symbol settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings And reconnect to the data feed. The old market statistics symbols will no longer work in new versions. These should be considered discontinued as of this time after updating. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-23 21:01:04] |
We have updated the Market Statistics documentation providing a technical explanation of how the statistics are calculated and also included descriptions for the new symbols: http://www.sierrachart.com/index.php?l=doc/SCMarketStatistics.php#Intro Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-25 17:33:42] |
User76539 - Posts: 18 |
I am using version 1097 and new market stats are not displayed:-( I can see only historical $TICK data. Can you help mehow to get the new market statistics in chart? thank you |
[2014-02-25 17:34:53] |
what symbol do you use for tick?
[2014-02-25 17:35:53] |
TICK-NYSE
[2014-02-25 17:37:27] |
ok.. on what broker connection are you?
[2014-02-25 17:44:04] |
InteractiveBrokers
[2014-02-25 17:49:41] |
TICK-NYSE is the correct symbol to use and will work with Interactive Brokers. If you are not getting data for that symbol start a new support request on this Support Board using this link: https://www.sierrachart.com/SupportBoard.php?do=NewThread&ForumID=0 We will need a copy of the Message Log, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-25 17:56:39] |
will do..
[2014-02-25 19:22:16] |
User92938 - Posts: 3 |
hi, Im using SC 1097 and I cant see market statistick. And i just can find NYSE TICK - value of the STICK +10,000 and doesnt work on REPLAY function. I ve update symbols but... Now when I start SC say download fail in each symbols. under i send my messeg log, thanks Software version: 1097 | 2014-02-25 20:00:36 Usage end date: 2014-03-06 | 2014-02-25 20:00:36 Enabled for: Sierra Chart Historical Data Service. | 2014-02-25 20:00:36 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-02-25 20:00:36 Active service: SC Historical Data | 2014-02-25 20:00:36 Time Zone: +01:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-02-25 20:00:36 2014-02-25 20:00:36 Local computer clock time | 2014-02-25 20:00:36 2014-02-25 19:00:36 GMT time | 2014-02-25 20:00:36 2014-02-25 20:00:36 Time zone adjusted time | 2014-02-25 20:00:36 Time difference to server time: 12 seconds. | 2014-02-25 20:00:36 Program path: C:\SierraChart\ | 2014-02-25 20:00:36 Data Files path: C:\SierraChart\Data\ | 2014-02-25 20:00:36 OS Version Number: 6.1 | 2014-02-25 20:00:36 Checking for new symbol settings for schd | 2014-02-25 20:00:36 Checking for large (over 250 MB) intraday data files to move data out of. Please wait.... | 2014-02-25 20:00:38 Completed checking of 58 Intraday data files (*.scid). | 2014-02-25 20:00:38 Symbol settings are up-to-date for schd | 2014-02-25 20:00:39 Connected to the Sierra Chart Historical Data Service. Historical Intraday data will be requested. | 2014-02-25 20:00:41 SC Historical Data - Starting real-time market data updates for: NQH14 | 2014-02-25 20:01:12 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:12 HD Request # 2 - Downloading Intraday chart data for NQH14 to the file NQH14.scid. Service: cme | 2014-02-25 20:01:12 HD Request # 2 - Download start Date-Time: 2014-02-25 19:47:21.0 | 2014-02-25 20:01:12 HD Request # 2 - Error downloading historical Intraday data for NQH14. Not downloading any Intraday data for symbol NQH4. Less than 30 minutes since last record Date-Time. | 2014-02-25 20:01:12 HD Request # 1 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for | 2014-02-25 20:01:12 SC Historical Data - Starting real-time market data updates for: YMH14 | 2014-02-25 20:01:12 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:12 HD Request # 3 - Downloading Intraday chart data for YMH14 to the file YMH14.scid. Service: cbot | 2014-02-25 20:01:12 HD Request # 3 - Download start Date-Time: 2014-02-25 19:47:06.0 | 2014-02-25 20:01:12 HD Request # 3 - Error downloading historical Intraday data for YMH14. Not downloading any Intraday data for symbol YMH4. Less than 30 minutes since last record Date-Time. | 2014-02-25 20:01:12 HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH14 | 2014-02-25 20:01:12 HD Request # 3 - Intraday download COMPLETE for YMH14 | 2014-02-25 20:01:12 Real-time Intraday chart data file updates started for YMH14 | 2014-02-25 20:01:12 SC Historical Data - Starting real-time market data updates for: $TICK | 2014-02-25 20:01:12 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:12 HD Request # 4 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: schd | 2014-02-25 20:01:12 HD Request # 4 - Download start Date-Time: 2014-02-25 19:34:00.0 | 2014-02-25 20:01:13 HD Request # 4 - Error downloading historical Intraday data for $TICK. Not downloading any Intraday data for symbol $TICK. Less than 30 minutes since last record Date-Time. | 2014-02-25 20:01:13 HD Request # 4 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $TICK | 2014-02-25 20:01:13 HD Request # 4 - Intraday download COMPLETE for $TICK | 2014-02-25 20:01:13 Real-time Intraday chart data file updates started for $TICK | 2014-02-25 20:01:13 SC Historical Data - Starting real-time market data updates for: EMDH4 | 2014-02-25 20:01:13 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:13 HD Request # 5 - Downloading Intraday chart data for EMDH4 to the file EMDH4.scid. Service: schd | 2014-02-25 20:01:13 HD Request # 5 - Download start Date-Time: 2014-02-18 22:30:21.0 | 2014-02-25 20:01:13 HD Request # 5 - Requesting historical Intraday Minute data for EMDH4 starting at 2014-02-18 15:30:21 (Exchange time). | 2014-02-25 20:01:13 SC Historical Data - Starting real-time market data updates for: ESH14 | 2014-02-25 20:01:13 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:13 HD Request # 6 - Downloading Intraday chart data for ESH14 to the file ESH14.scid. Service: cme | 2014-02-25 20:01:13 HD Request # 6 - Download start Date-Time: 2014-02-25 19:47:40.0 | 2014-02-25 20:01:13 HD Request # 6 - Error downloading historical Intraday data for ESH14. Not downloading any Intraday data for symbol ESH4. Less than 30 minutes since last record Date-Time. | 2014-02-25 20:01:13 HD Request # 6 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH14 | 2014-02-25 20:01:13 HD Request # 6 - Intraday download COMPLETE for ESH14 | 2014-02-25 20:01:14 Real-time Intraday chart data file updates started for ESH14 | 2014-02-25 20:01:14 HD Request # 5 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EMDH4 | 2014-02-25 20:01:18 HD Request # 5 - Intraday download COMPLETE for EMDH4 | 2014-02-25 20:01:18 Real-time Intraday chart data file updates started for EMDH4 | 2014-02-25 20:01:18 File >> Disconnect selected. | 2014-02-25 20:01:44 Disconnected from the Sierra Chart Historical Data Service. | 2014-02-25 20:01:44 Connected to the Sierra Chart Historical Data Service. Historical Intraday data will be requested. | 2014-02-25 20:01:48 SC Historical Data - Starting real-time market data updates for: ESH14 | 2014-02-25 20:01:48 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:48 HD Request # 7 - Downloading Intraday chart data for ESH14 to the file ESH14.scid. Service: cme | 2014-02-25 20:01:48 HD Request # 7 - Download start Date-Time: 2014-02-25 19:47:40.0 | 2014-02-25 20:01:48 HD Request # 7 - Error downloading historical Intraday data for ESH14. Not downloading any Intraday data for symbol ESH4. Less than 30 minutes since last record Date-Time. | 2014-02-25 20:01:48 HD Request # 7 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH14 | 2014-02-25 20:01:48 HD Request # 7 - Intraday download COMPLETE for ESH14 | 2014-02-25 20:01:48 Real-time Intraday chart data file updates started for ESH14 | 2014-02-25 20:01:48 SC Historical Data - Starting real-time market data updates for: YMH14 | 2014-02-25 20:01:48 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:48 HD Request # 8 - Downloading Intraday chart data for YMH14 to the file YMH14.scid. Service: cbot | 2014-02-25 20:01:48 HD Request # 8 - Download start Date-Time: 2014-02-25 19:47:06.0 | 2014-02-25 20:01:48 HD Request # 8 - Error downloading historical Intraday data for YMH14. Not downloading any Intraday data for symbol YMH4. Less than 30 minutes since last record Date-Time. | 2014-02-25 20:01:48 HD Request # 8 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMH14 | 2014-02-25 20:01:48 HD Request # 8 - Intraday download COMPLETE for YMH14 | 2014-02-25 20:01:48 Real-time Intraday chart data file updates started for YMH14 | 2014-02-25 20:01:48 SC Historical Data - Starting real-time market data updates for: NQH14 | 2014-02-25 20:01:48 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:48 HD Request # 9 - Downloading Intraday chart data for NQH14 to the file NQH14.scid. Service: cme | 2014-02-25 20:01:48 HD Request # 9 - Download start Date-Time: 2014-02-25 19:47:21.0 | 2014-02-25 20:01:48 HD Request # 9 - Error downloading historical Intraday data for NQH14. Not downloading any Intraday data for symbol NQH4. Less than 30 minutes since last record Date-Time. | 2014-02-25 20:01:48 HD Request # 9 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH14 | 2014-02-25 20:01:48 HD Request # 9 - Intraday download COMPLETE for NQH14 | 2014-02-25 20:01:48 Real-time Intraday chart data file updates started for NQH14 | 2014-02-25 20:01:48 SC Historical Data - Starting real-time market data updates for: EMDH4 | 2014-02-25 20:01:49 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:49 HD Request # 10 - Downloading Intraday chart data for EMDH4 to the file EMDH4.scid. Service: schd | 2014-02-25 20:01:49 HD Request # 10 - Download start Date-Time: 2014-02-18 22:30:21.0 | 2014-02-25 20:01:49 HD Request # 10 - Requesting historical Intraday Minute data for EMDH4 starting at 2014-02-18 15:30:21 (Exchange time). | 2014-02-25 20:01:49 SC Historical Data - Starting real-time market data updates for: $TICK | 2014-02-25 20:01:49 The SC Historical Data service does not provide real-time data. | 2014-02-25 20:01:49 HD Request # 10 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for EMDH4 | 2014-02-25 20:01:51 HD Request # 10 - Intraday download COMPLETE for EMDH4 | 2014-02-25 20:01:51 Real-time Intraday chart data file updates started for EMDH4 | 2014-02-25 20:01:51 HD Request # 11 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: schd | 2014-02-25 20:01:51 HD Request # 11 - Download start Date-Time: 2014-02-25 19:34:00.0 | 2014-02-25 20:01:51 HD Request # 11 - Error downloading historical Intraday data for $TICK. Not downloading any Intraday data for symbol $TICK. Less than 30 minutes since last record Date-Time. | 2014-02-25 20:01:51 HD Request # 11 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $TICK | 2014-02-25 20:01:51 HD Request # 11 - Intraday download COMPLETE for $TICK | 2014-02-25 20:01:51 Real-time Intraday chart data file updates started for $TICK | 2014-02-25 20:01:51 |
[2014-02-25 22:43:30] |
We have added support for the new Sierra Chart market statistics symbols to the Sierra Chart Historical Data Service. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings After this open one of the available symbols through File >> Find Symbol >> Market Stats. Also, EMDH4 is not a valid symbol for the Sierra Chart Historical Data Service. The equivalent symbol is EWH14. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-25 22:46:17
[2014-02-27 15:59:06] |
jdconner - Posts: 27 |
I wonder what a advance decline line would look like using today's open instead of yesterdays close. Would that give a truer picture of today's strength or weakness for intraday trading. Thanks JDConner |
[2014-02-27 17:24:25] |
Perhaps, but that is not the standard.
[2014-02-28 08:35:11] |
Bapovs01 - Posts: 24 |
I have a problem with FXCM and the new statistics. I used to have the $tick symbol, which worked perfect icm with FXCM feed. Now it is impossible to get the two working together. It is either FXCM datafeed for updating the prices for FXCM or choose SC marketstats for the new symbol TICK. It is not working together, even after the new tutorial for the new symbols. Is this a known issue? |
[2014-02-28 09:28:27] |
We see you are using the FXCM Trading service. The new market statistics symbols were not previously set up for that service. They are now. Update the symbol settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings The new symbol you need to use is TICK-NYSE Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-28 09:29:07
[2014-02-28 09:30:58] |
Nearly 5 years of history was added for the US Dollar Index symbol. To get more history for the USDX symbol, refer to help topic 42.1: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-28 11:48:52] |
I did exactly the things in the description. the global symbol settings is FXCM FIX Trading. I get all the symbols that FXCM provides. When selecting another service -> SC Market Stats i get all the market stats incl the TICK. When disconnecting and reconnecting again the symbols don't show up when selecting file-find symbol. I only get in map market stats USDX and get FXCM FIX TRADING (THIS INSTANCE) grayed out. Before the change i used the market stats form your side and the symbol data from FXCM. Please advice. |
[2014-02-28 17:40:28] |
When we updated the Symbol Settings earlier, there was a slight error with that. It is now corrected. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings You will definitely get the symbols now as long as there is not a communication problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-28 20:08:14] |
tobi - Posts: 351 |
Nearly 5 years of history was added for the US Dollar Index symbol. To get more history for the USDX symbol, refer to help topic 42.1: I've done so, but still no data earlier than the 17th/18th of February!?http://www.sierrachart.com/index.php?l=doc/helpdetails42.html Here's the message log (with Days to Display/Load = 75 and Max Historical Intraday Days ... = 150: Reloading all charts with filename: USDX.scid | 2014-02-28 21:04:25 HD Request # 21 - Downloading Intraday chart data for USDX to the file USDX.scid. Service: statscalc | 2014-02-28 21:04:25 HD Request # 21 - Download start Date-Time: 00:00:00.0 | 2014-02-28 21:04:25 HD Request # 21 - Using server: ds5.sierracharts.com port 10149 | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Program Files\_tb\trade\sc\fx\Data\USDX.scid | 2014-02-28 21:04:25 The network socket is connected. | 2014-02-28 21:04:25 HD Request # 21 - Sending historical data logon request message. | 2014-02-28 21:04:25 HD Request # 21 - Requesting Intraday data. Max. days to return: 150. Record interval: 1 | 2014-02-28 21:04:25 HD Request # 21 - Decompressing data. | 2014-02-28 21:04:25 HD Request # 21 - Receiving Intraday data for USDX starting at 2014-02-17 23:10:14 | 2014-02-28 21:04:25 HD Request # 21 - Timestamp of first Intraday data file record written: 2014-02-17 23:10:14 | 2014-02-28 21:04:25 Chart #20 has tagged chart #14 for full recalculation. Chartbook: .ymxx.cht | 2014-02-28 21:04:26 Chart #19 has tagged chart #8 for full recalculation. Chartbook: .ymxx.cht | 2014-02-28 21:04:26 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: .ymxx.cht | 2014-02-28 21:04:26 Chart #14 is performing a full recalculation because it has been tagged. Chartbook: .ymxx.cht | 2014-02-28 21:04:26 Chart #12 has tagged chart #6 for full recalculation. Chartbook: .senti.cht | 2014-02-28 21:04:27 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: .senti.cht | 2014-02-28 21:04:27 Chart #21 has tagged chart #15 for full recalculation. Chartbook: .ymxx.cht | 2014-02-28 21:04:27 Chart #21 has tagged chart #22 for full recalculation. Chartbook: .ymxx.cht | 2014-02-28 21:04:27 Chart #21 has tagged chart #8 for full recalculation. Chartbook: .ymxx.cht | 2014-02-28 21:04:27 Chart #22 is performing a full recalculation because it has been tagged. Chartbook: .ymxx.cht | 2014-02-28 21:04:27 Chart #8 is performing a full recalculation because it has been tagged. Chartbook: .ymxx.cht | 2014-02-28 21:04:27 Chart #15 is performing a full recalculation because it has been tagged. Chartbook: .ymxx.cht | 2014-02-28 21:04:27 The network socket for historical data has been closed. | 2014-02-28 21:04:35 HD Request # 21 - Received 856263 records from 2014-02-17 23:10:14 to 2014-02-28 21:04:34 (10.9 days) and wrote 856263 records for USDX | 2014-02-28 21:04:35 Added 2 Time and Sales records to Intraday data file for USDX after download. | 2014-02-28 21:04:35 HD Request # 21 - Intraday download COMPLETE for USDX | 2014-02-28 21:04:35 Real-time Intraday chart data file updates started for USDX | 2014-02-28 21:04:35 |
[2014-02-28 20:27:10] |
It is now corrected. Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings You will definitely get the symbols now as long as there is not a communication problem. The problem has been solved! thank you. |
[2014-03-03 19:22:52] |
User40526 - Posts: 166 |
I cannot figure out why my market statistic symbol ADR_NYSE displays as 0.xx instead of as xxxx.00. I have tried to adjust Chart/Chart Settings/Price Display Format and Tick Size to no avail. I am using version 1097. Please advise.
