Date/Time: Sat, 18 May 2024 20:37:39 +0000
[User Discussion] - Gartley Pattern Finder
View Count: 3076
[2014-02-08 03:31:27] |
FFTrader - Posts: 180 |
http://www.sierrachart.com/supportboard/showthread.php?t=15486 Did anyone manage to get the above Gartley Pattern Finder working? I loaded it with Version 1090 and nothing is appearing on the chart. |
[2014-02-08 03:34:24] |
Nevermind - ok, changing the sensitivity. It seems to work now. Found a bullish pattern, etc.
Date Time Of Last Edit: 2014-02-08 03:34:34
[2014-02-08 17:30:00] |
Ok, it is working "somewhat" ... The attached is a 240min chart of GC's April 2014 futures. Settings of the study is: Length = 200, Strength = 13, Tolerance = 0.8866 ... for the 88.66% Fibonacci level. So far so good right? Not quite - when I tried to load 50 or less days of data, the study disappears ... and 94 days of data or more, it also disappears! It will only show up between 51 and 93 days of data. One more twist here: if I load 94 days of data, ONLY the pattern on the right appears. What is going on???? Can Sierra Support answer this question and explain why ONLY certain amount of data works? Nonetheless - I will try to message the indicator's creator Scottorama ... |
20140208 GC 240min.PNG / V - Attached On 2014-02-08 17:15:34 UTC - Size: 155.01 KB - 838 views |
[2014-02-08 17:48:08] |
ejtrader - Posts: 688 |
FFTrader - unless source code is available - it would be difficult to analyze this.
[2014-02-10 13:37:41] |
Yeah, I am planning to contact the developer. Scottorama - if you are reading this can you help please? Support had also suggested that I contact Scott.
