Date/Time: Sun, 05 May 2024 16:55:00 +0000
Market Statistics, US Dollar Index, other/new FX indices
View Count: 5187
[2014-03-31 07:18:23] |
tobi - Posts: 351 |
Sorry to bug you with that, but could you tell me when approx. you will get to adding the new FX-indices to the IB service?
[2014-03-31 07:25:52] |
you will get to adding the new FX-indices to the IB service? This is now done. Restart Sierra Chart to get the indexes.Is is correct, that the intraday history starts at 03/26/14 at 09:15 PM EST for the FX-indices? Yes.Thread review: Reviewed/Completed posts: 15 through 25. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-03-31 07:26:04
[2023-02-21 09:49:59] |
User733806 - Posts: 3 |
I would like for the FX-indices to be added to the iqfeed service. Is that possible? In particular I am interested in the dollar index calculation. thank you |
[2023-02-21 21:18:03] |
Sierra_Chart Engineering - Posts: 14234 |
What you can do is install another copy of Sierra Chart set to use the Service SC Data-All Services. Refer to: Using Multiple Data and Trading Services at the Same Time You can then access the indices in that installation: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-21 21:18:38
