Date/Time: Thu, 09 May 2024 03:39:22 +0000
[User Discussion] - Flex Renko Open difference
View Count: 2964
[2013-04-10 19:22:29] |
N!co - Posts: 140 |
Hi, I am building a spreadsheet for trading, and I need to refer to the OPEN of a Flex Renko candle there is a difference to the value of the OPEN on the chart and the value that is showed by the crosshair I understand why this is the case , but I need to refer to the OPEN value on the CHART (in this example 1.30599 vs 1.30610 How would I need to do this Thank you Date Time Of Last Edit: 2013-04-10 19:59:01
FlexRenko_open.PNG / V - Attached On 2013-04-10 19:57:34 UTC - Size: 233.23 KB - 843 views |
[2013-04-11 18:05:31] |
We will have to add a new study to support this. The name might be: Renko Visual Open/Close Values We should have this out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-11 18:16:23] |
N!co - Posts: 140 |
Hi, Thank you for you answer and I look forward to see the new study implemented as a lot of other Renko charts users will i believe Kind Regards, |
