Date/Time: Mon, 13 May 2024 06:16:30 +0000
[User Discussion] - TTNet difference BIDxASK vs IQfeed/SC
View Count: 4393
[2013-11-22 19:22:14] |
User025731 - Posts: 8 |
Hallo SC, I have got the data and trading service with AMP/TTnet. I have compare bid/ask volume between IQfeed/ZenFire/SierraChart/and TTNet. IQfeed/ZenFire and SierraChart has the same bid/ask, but AMP/TTnet ist very different. Can you tell me or help me why is TTNet different? Which data are correct? (according to this I suppose that TTNet isn´t)...? Thank you a very much. Date Time Of Last Edit: 2013-11-22 19:28:26
IQfeed.jpg / V - Attached On 2013-11-22 19:27:31 UTC - Size: 357.21 KB - 930 views Data_SC.jpg / V - Attached On 2013-11-22 19:27:39 UTC - Size: 403.67 KB - 925 views ZenFire.png / V - Attached On 2013-11-22 19:27:48 UTC - Size: 89.49 KB - 662 views |
[2013-11-22 19:30:36] |
ganz - Posts: 1048 |
AC66731 http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#ServicesThatSupportBVandAV according to this I suppose that TTNet isn´t
that's it |
[2013-11-22 20:27:17] |
TT FIX and TT Net do not provide accurate Bid Volume or Ask Volume.
[2014-04-27 08:41:28] |
Martin - Posts: 5 |
There have been any progress on this? Time and sales, delta cumulative volume seem don't work properly Since I am in process to set my AMP account with TTNet, I am just wondering if there will be a definitive solution for this issue I am a scalper so this aspect is very important AMP/TTNet is a good solution for the cost of round turn, but I can't accept when I trade, that very often ticks on bid are confused with ask and viceversa After a long time, what is the situation now? Thank You |
[2014-04-27 09:04:33] |
There is no change and we would not expect there to have been any change. We recommend using the Sierra Chart Exchange Data Feed for accurate data: http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-04-27 17:02:19] |
vegasfoster - Posts: 444 |
To clarify, this is not a Sierra Chart issue, it is a TT issue. TT is the bargain basement feed of the trading world. You use it because it's cheap, or you are broke, or you are cheap and broke, like me ;)
[2014-04-27 17:22:56] |
Sawtooth - Posts: 3995 |
TT is reliable and fast and inexpensive. Its only negative is bid/ask inaccuracy.
