Date/Time: Sat, 04 May 2024 07:03:54 +0000
volume imbalance charts
View Count: 18926
[2018-03-28 17:58:44] |
Programming_autotrading_phonesup - Posts: 59 |
'Dominant Side Auction' option mentioned in this post is no longer available / called like that in Sierra Chart. What is the new name?
[2018-03-28 18:14:56] |
Sierra Chart has what you require. There are many text and background coloring methods which are documented here: Numbers Bars: Numbers Bars Text Coloring Methods Numbers Bars: Diagonal Comparison of Bid Volume and Ask Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
