Date/Time: Mon, 29 Apr 2024 20:17:47 +0000
Orderflowanalytics-style reversal bars.
View Count: 30965
[2017-10-30 19:50:23] |
Letting you all know, that in the latest version of Sierra Chart, there is a new parameter for Reversal Bars to specify the minimum length before a reversal can occur.
[2017-10-31 06:02:47] |
Zdislav - Posts: 73 |
What is the actual logic for creation of the new reversal bar? It seems to be quite different from the bars presented in this thread. Do you use operator "greater" or greater or equal" in bar length comparison and reversal comparison? I think the request posted here by @Samir could be solved by implementation of this. Z. |
[2017-10-31 06:25:17] |
GREATER_EQUAL_OPERATOR for the bar length.
[2017-10-31 06:52:01] |
OK, and for the reversal? From the documentation of reversal bars it is not clear if a new bar starts after "reaching" or "exceeding" reversal amount. If I can remeber correctly, there are less OFA bars than new reversal bars with the same setting. I also got feedback from active users that my bars are accurate (in comparison with other platforms providing this graph type).
Date Time Of Last Edit: 2017-10-31 06:52:35
[2017-10-31 07:26:59] |
The Reversal amount has to be reached or exceeded. The operator is: GREATER_EQUAL_OPERATOR
[2018-04-07 03:02:10] |
User123235 - Posts: 46 |
Hi, I uploaded the OFA zip and extracted but getting "not allowed to use" message, help? Thanks Date Time Of Last Edit: 2018-04-07 15:34:03
[2018-04-07 18:36:38] |
You can either visit our website forum.obchodni-indikatory.cz and download it from there among other stuff, or e-mail me your SC account username so I can make it available for you. Z. |
[2018-04-08 01:36:34] |
Thanks Z, I sent you DM with username.
[2020-02-19 23:36:11] |
User491299 - Posts: 26 |
Is anybody can help me to use this study? Downloaded it put in Data folder but sierra don`t see it at all.
[2020-02-21 03:54:36] |
Refer to the following for things to check: Resolving Custom Study File and Access Issues: Custom Study Problems - Things to Check Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-21 07:08:49] |
User271808 - Posts: 2 |
thanks for response. I checked everything but nothing works for me. I can`t even see those dll and cpp in my Sierra. Could you help me with those probe and rotation bars? Pleaseee.
[2020-04-17 15:23:55] |
Ackin - Posts: 1865 |
User271808) Zdislav gave me all his source codes for all the studies he did (also OFA Bars - last change March 20, 2019). The few of them in this thread will be uploaded in 64-bit version tonight. you can download ACSIL study for free from our CZ/SK forum (just Study in dll file, not code). contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-04-17 15:43:19
