Date/Time: Tue, 21 May 2024 00:45:21 +0000
Decimal point in DOM price
View Count: 2560
[2013-07-31 22:39:30] |
acuity - Posts: 10 |
How do I get the DOM to display a decimal point for the ES in the price column? Thanks.
[2013-08-01 10:00:10] |
Could you please provide us an image of what you see now. Follow these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-01 12:35:11] |
Requested screenshot attached
SNAG-0002.png / V - Attached On 2013-08-01 12:34:36 UTC - Size: 37.22 KB - 560 views |
[2013-08-02 11:03:00] |
There are several settings to adjust for this in Chart >> Chart Settings: Value Format Tick Size Real-Time Price Multiplier Historical Price Multiplier You may also want to update to the latest prerelease and use the new CTS FIX connection. You will need to follow these instructions for this: https://www.sierrachart.com/index.php?l=doc/CTS_T4.php#UsingFIX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-02 12:22:23] |
Updating to the prerelease had no effect, can you just tell me exactly which chart setting(s) to change to have DOM price accurately display the decimal point, instead of listing all the possible parameters to change!?
[2013-08-02 21:13:06] |
We are just hesitant to have people make these changes unless they fully understand them. This is why we did not provide details and wanted you to determine how these should be set based upon the documentation. The way that the prices are quoted is based upon the way that CTS T4 system provides data and you will also see the same quoted values in the T4 software. So we recommend leaving the values as they are. Value Format = .01 Tick Size = .25 Real-Time Price Multiplier = .01 Historical Price Multiplier = .01 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-02 21:15:34
