Date/Time: Sun, 05 May 2024 12:52:04 +0000
Paper trading of spread trading?
View Count: 1751
[2013-06-21 00:58:15] |
It is not possible to trade the values from the Difference study. You will only be able to trade using the underlying main price data in the chart. If the data or trading service you are using provides exchange traded spreads and strategies, then you can trade directly on those symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-21 09:11:08] |
Replay is not supported in Historical Daily charts. However, in an Intraday chart you can set the chart bars to 1 day per bar and then replay that chart.
