Date/Time: Sun, 19 May 2024 21:02:00 +0000
988: Changing contract month, DOM is messed up
View Count: 2108
[2013-06-17 14:49:00] |
YSS - Posts: 107 |
If you change the contract to a new month with version 988 the dom looks messed up. Pressing the INS key who should refresh the dom doesn't help. I need to remove the DOM and put a new one. thanks for fixing. |
sierrachartproblemDOM.png / V - Attached On 2013-06-17 14:48:48 UTC - Size: 34.77 KB - 579 views |
[2013-06-17 17:50:02] |
tobi - Posts: 351 |
I'm seeing the same thing when changing FX symbols via Associated Watch List. What helps is right-clicking on the DOM and selecting Auto Scale the ChartDOM. I'd be nice if that would be done automatically though! Date Time Of Last Edit: 2013-06-17 17:50:27
[2013-06-17 18:10:16] |
Assuming the problem is due to scaling, we will make Auto Scale the ChartDOM automatic when changing the symbol on a Trade DOM.
[2013-06-18 08:03:20] |
tobi - Posts: 351 |
That would be nice. Please let us know here or in the Log of Changes when you have done so.Thank you. |
