Date/Time: Sat, 04 May 2024 20:46:10 +0000
Can you help GFDL (India) in solving the disconnection issue?
View Count: 5943
[2015-11-20 20:31:45] |
User55905 - Posts: 34 |
Any luck? Its now more than 4 months since the official talks on integration have started. Glimmer hope... |
[2015-11-21 02:01:22] |
We are following up with them again: Hello,
It is now approximately 2 months later. You can see the latest post from someone very interested in the integration between Sierra Chart and True Data here: Can you help GFDL (India) in solving the disconnection issue? | Post: 74247 Thank you, On 2015-09-29 6:43 PM, Kapil wrote: > Hello, > Great to hear that.. > Yes we are still working on Phase 1 which should take another month. > Sierra Charts is in Phase 2. > We will keep you updated. > Best Regards, > Kapil > Managing Director, TrueDataâ„¢ Financial Information Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-07 18:15:31
[2016-06-07 13:32:23] |
User95370 - Posts: 28 |
Any updates? This is hopeless.
[2016-06-07 18:14:26] |
We have given up on Indian data providers and will not spend any further time with them. We are working on our own solution with direct NSE connectivity for both market data and trading, but this is something that takes time and is conditional upon being able to successfully work with a major broker in India. It is something that we are actively doing and we will see what happens. We cannot make any promises. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-07 19:30:28] |
Can you disclose which brokers are you in talks with in India for NSE and MCX? Are you in talks with Zerodha or RKSV ? I ask because these two are basically new entrants to the Indian broking market and are quite popular among traders who look for low fees. These are discount brokers I believe.
[2016-06-07 20:44:28] |
We do not know at this time. We have not yet approached any of them.
[2016-07-20 01:47:46] |
User279714 - Posts: 21 |
I also heard Barchart provides indian data Could you workout with them
