Date/Time: Sun, 05 May 2024 01:57:01 +0000
Can you help GFDL (India) in solving the disconnection issue?
View Count: 5946
[2015-07-03 10:13:32] |
User279714 - Posts: 21 |
Please go through this http://www.truedata.in/information/contact For Technical / Billing Support Mail us at : support@truedata.in For Partnering With Us Mail us at: contact@truedata.in Send a Direct Message to the Managing Director Mail us at: kapil.marwaha@truedata.in They are in serious expansion of business contact them |
[2015-07-04 04:55:38] |
We are contacting them now.
[2015-07-04 16:20:12] |
I have informed Mr Kapil who is the Managing Director of the company and his email id is kapil.marwaha@truedata.in . You can contact him for the same. I would like to request you to extend my trial so i too can try to test the data if it can be compatible. Regards K.D |
[2015-07-05 00:23:56] |
Your trial has been extended, but the integration is not likely to be complete for a while. At that time ask for another extension. Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-06 18:06:28] |
We have discussed integration between http://www.truedata.in and Sierra Chart, with True Data. Based upon the what has been said, we believe that this is very likely to happen. As far as how long this will take, we are not sure but hopefully within three months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-07 11:33:10] |
Can i have an idea that how many people use Indian data with sierra chart
[2015-07-07 15:21:57] |
If you are referring to the number of users using Global Data Feeds, we would expect this is just a very small number. Probably less than 10 but we are not completely sure.
[2015-07-07 16:31:13] |
heyram - Posts: 8 |
any alternative data feeds you suggest for indian traders who want to use sierra charts? I loved sierra charts in first look. Been banging with esignal but in vain. then GDFL again in vian but still I have hopes in sierra |
[2015-07-07 16:36:25] |
We expect this data feed will be supported: http://www.truedata.in/ However, not at this moment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-07 16:46:15] |
heyram - Posts: 8 |
You have choosen globaldatafeeds as data provider for indian markets? But they provide only level 1 data. so I cannot trade using DOM profile? with only level 1 data, can i use TPO and number bars? I am new to markets.so sorry for any wrong questions. does truedata.in provide level 2/3 data? We will be happy if atleast things started from both the sides. |
[2015-07-07 21:40:13] |
Currently only Global Data Feeds is supported as a non-trading service data provider for Indian Markets. Global Data Feeds does not provide market depth data. Numbers Bars and TPO Profile charts do not require market depth data. We are not sure about the data capabilities of True Data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-08 01:25:25] |
What would be the cost of developing the DTC protocol for connecting to your service.
[2015-07-09 09:16:10] |
heyram - Posts: 8 |
Ok thanks for info. what about DOM trading in GFDL? Is it possible now? Going with truedata will reinvent the whole wheel while with GFDL , its only about solving an issue which will take very less time when compared to truedata.Just my opinion on it. If you decided with truedata, kindly check their level 2/3 data capability for DOM trading. Regards |
[2015-07-09 18:29:50] |
What would be the cost of developing the DTC protocol for connecting to your service. What service are you referring to? And we could not tell you anything about cost.what about DOM trading in GFDL? Is it possible now? Global Data Feeds is a data provider. Not a trading service. So Trading is not supported with that service.
[2015-07-14 14:36:45] |
User55905 - Posts: 34 |
@heyram & @User279714 - SC is best & most sought out trading platform among traders. SC can't do anything when GFDL is incapable or not interested in solving the disconnection issue! #Go through the post #21 of this present thread. #Also, please refer from post 474 onwards in this forum. From where you can get the jist of how unprofessional and irresponsible GFDL is!! http://www.inditraders.com/data/3684-gfdl-rt-data-amibroker-metastock-advanced-get-ninjatrader-ensign-48.html I have been behind them since past 1 year. But these shameless creatures are not at all interested in serving their clients. For such a small issue, they have taken us for a ride and still maintain on their website that they offer Sierra Chart - How unprofessional and liars they are! They know once a trader is caught in their NET, ultimately he/she will give in and chose another platform with same data feed. So, they get clients for ever by false ads on their website! Date Time Of Last Edit: 2015-07-14 14:40:29
[2015-07-14 15:11:36] |
heyram - Posts: 8 |
@User55905 Actually, you can file an RTI on their(GFDL) false service . Lets hope for good to come. Date Time Of Last Edit: 2015-07-16 16:24:35
[2015-07-16 16:24:07] |
heyram - Posts: 8 |
TrueData customer care called me back....very very responsible gentlemen out there.... I was promised that sierra chart integration would be done in 3 months. If someone want to give some features suggestion, it is the right time. Hope someone will do it |
[2015-07-16 18:36:32] |
I was promised that sierra chart integration would be done in 3 months. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-08-05 08:05:44] |
heyram - Posts: 8 |
Dear Sierra Charts and TrueData, I am very eager to ask How is the progress? Awaiting your reply, Regards of HeyRam |
[2015-08-05 08:12:57] |
This is expected to be available within the next three months.
[2015-08-05 09:38:20] |
heyram - Posts: 8 |
Thats pleasing!! thank you |
[2015-09-09 17:28:40] |
Any updates from TrueData.in?? Please push for it and have a word with them. Losing out on patience now! |
[2015-09-09 18:18:55] |
No updates yet. If we do not hear from them in about a month we will follow up with them.
[2015-10-20 07:21:34] |
Any updates from TrueData.in? It's now more than 3 months since you have initiated the talks with them. Any hopes for Indian traders after the disastrous, unprofessional & irresponsible services offered by GFDL. Are they still alive or have closed their shop? |
[2015-10-20 07:28:47] |
Yes we communicated with them about two weeks ago. We do fully expect that integration will begin sometime soon. Not sure how fast it will come. We would hope it would be sometime in the next month.
[2015-11-20 20:31:45] |
Any luck? Its now more than 4 months since the official talks on integration have started. Glimmer hope... |
