Date/Time: Wed, 25 Nov 2026 21:46:17 +0000
Query on EUREX data feed through Rithmic
View Count: 2186
| [2025-05-12 19:33:26] |
| YannRicordeau - Posts: 1 |
Hello, I'm looking to Trade EUREX (FDAX) through Rithmic on SC with TheTradingPit propfirm, which is probably the only prop providing EUREX data through Rithmic. EUREX data from Rithmic works fine on R Trader, but it doesn't on SC. Also, CME data works just fine on the same account on SC through Rithmic. But as soon as I switch to FDAX symbol, I see an error message " Market data only supported with SC data feed for symbol FDAX.." (screenshot attached) Is it not possible to use Rithmic EUREX data on SC ? Would it works to use the SC Data feed for EUREX and trade through the rithmic account on SC ? (As Apex prop account / Denali data) Do I need to pay the data feed from both rithmic and SC to do so ? I've looking on many threads about this issue without luck, thanks to the team for your work and help ! |
Attachment Deleted. |
| [2025-05-12 21:40:40] |
We do not support EUREX data from any third party. Therefore, in order to get EUREX data, you need to get it from our Denali Exchange Data Feed. If you activate the EUREX exchange within our Denali Exchange Data Feed, then you will be getting the real-time data for EUREX from us while continuing to get the CME Group data from Rithmic. Unless you are using another system for placing orders, or viewing information related to the EUREX data from Rithmic, then you would not need that data from Rithmic. Follow the instructions at the following link to setup the data for EUREX: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
