Date/Time: Wed, 25 Nov 2026 21:46:18 +0000
Single total volume by price column on numbers bars.
View Count: 734
| [2025-05-11 17:18:43] |
| HeroAlpha - Posts: 2 |
I need to create a numbers bars chart that will display only total volume volume profile per candle and have the coloring informed by the bid/ask. I can not find a way to merge the bid/ask volumes at price into a single number/profile. See attached example of what I need to achieve.
| [2025-05-12 14:29:24] |
We do not know what you mean by "merge the bid/ask volumes at price into a single number/profile". To have a Total Volume Profile with the coloring of the profile based on the Ask Volume or Bid Volume percentage (whichever is dominant) then set the following in the Numbers Bars study: - Column 1 Background Type: Volume Profile - Column 1 Background Coloring Method: Based on AskVol/BidVol Percentage You can select a different background coloring method depending on exactly what you want to color based on. Refer to the following: Numbers Bars: Numbers Bars Background Types Numbers Bars: Numbers Bars Background Coloring Methods For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
