Date/Time: Wed, 25 Nov 2026 20:51:58 +0000
Trading Technologies Connection
View Count: 1407
| [2025-05-08 23:49:23] |
| KB - Posts: 1 |
Hi - I recently joined a Chicago-based prop firm. I understand I now need to update my status to professional for the Denali data feed, but that is besides the point. I execute through TT but am interested in linking TT to Sierra Chart. I don't need to execute through Sierra, I just need real-time data to flow through for charts, footprints, etc. Is a TT to Sierra link an option? If so, how do I get this up and running? Thanks for your help! |
| [2025-05-09 11:33:27] |
| Sierra_Chart Engineering - Posts: 25483 |
No: Is a TT to Sierra link an option?
You will need to use the Denali Exchange Data Feed for data: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-06-27 23:32:11] |
| Ryan Bailey - Posts: 59 |
I'm also about to join a large firm in Chicago and I will also be using TT for futures and options. I've been using Sierra for 7yrs and have become comfortable with the platform and execution via the charts. I'm very comfortable with the Denali Data and I see that You have an option for "TT futures order routing" I want to confirm I can use this to connect and execute with as long as I'm using Denali Data? Thanks and look forward to hearing back Date Time Of Last Edit: 2025-06-27 23:49:56
| [2025-06-28 22:26:07] |
No, we will not allow that to be used by any new users: I want to confirm I can use this to connect and execute with as long as I'm using Denali Data?
TT actually has been phased out and is used only by one firm only by a small number of users. We do not want to go through all of the complex technical details but it simply cannot be used by any new user. We strongly advise to use Teton order routing instead: Sierra Chart Teton Futures Order Routing If the clearing firm you want to use is not supported, we can try to work with that firm to support Teton. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-06-28 22:26:44
