Date/Time: Wed, 25 Nov 2026 21:46:16 +0000
Need Help With DATA! (if Not Working Will Switch)
View Count: 941
[2025-05-08 18:17:31]
AlexH4 - Posts: 28
i didn't resolve and find why My chart scale Live price is jumping Up And Down Without folowing the candle bar??? is it very lagging between price and candle stick update!
aviously is a DATA Problem Maybe is because the trial is active at the same time?? can you plz remove the tiral on my account (Do you think it can be related to this?)
imageSierra price lag.png / V - Attached On 2025-05-08 18:17:09 UTC - Size: 512.28 KB - 343 views
imagesierra chart lag 2.png / V - Attached On 2025-05-08 18:17:21 UTC - Size: 891.32 KB - 345 views
[2025-05-08 18:51:12]
Your account is not on a trial. Check the session times for the chart:
Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.3 - Session Start Time and End Time not Covering Current Time
If they do cover the time span of the current trading, then what you are seeing is very unusual. Really should not be happening. We may need to do a remote assistance session with you.
[2025-05-08 21:40:16]
OK we understand what the problem is. This is due to Odd lot trades. Do you want to see Odd lot trades? An Odd lot trade is a trade below 100 shares.
Date Time Of Last Edit: 2025-05-08 21:40:31
[2025-05-08 23:03:32]
AlexH4 - Posts: 28
-So if i understand the chart Bar itself is setup to Odd Lot Trade to Off Or X.(Witch we cant control)
-And the Chart price Scale itself is default to On(Yes) (X maybe 100Shares) on the Data/Trade Service Setting?
Finally! setting Odd Lot Trades to NO in Data/Trade Service will match together the chart Bar And the Price on the scale.!
Date Time Of Last Edit: 2025-05-08 23:25:48
[2025-05-10 01:21:42]
See:
Chart Settings: Include Odd Lot Equity Trades (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
Data/Trade Service Settings: Process Known Odd Lot Equity Trades for DTC Services (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings)
