Date/Time: Wed, 25 Nov 2026 21:56:11 +0000
[Programming Help] - Feature Request
View Count: 698
[2025-05-08 12:28:05]
User469888 - Posts: 5
Hi there, I have a feature request if you don't mind )). Is it possible to add something to custom rectangle properties where I can preset the exact size of the rectangle, so that it can be placed on a chart with a single click, instead of dragging it to size each time?
Thanks in advance!
[2025-05-09 06:20:57]
Tony - Posts: 738
Not sure if you into coding, this probably can be done by ACSIL, if you could post your request in detail, someone might be able to write a custom study to meet your need.
[2025-05-09 18:58:02]
You can specify a "Start Date-Time" and "End Date-Time" for a rectangle, which will set it to be a certain size based on the bar period of the chart. Refer to the information for these options at the following link:
Chart Drawing Tools: Tool Settings
