Date/Time: Wed, 25 Nov 2026 21:56:12 +0000
Confirmation of DTC Protocol Access with Teton Order Routing
View Count: 1027
| [2025-05-08 02:37:41] |
| User641185 - Posts: 1 |
Hello, I’m planning to open a trading account with a broker that offers Teton Order Routing and Denali Data Feed to use exclusively with Sierra Chart. Before proceeding, I would like to confirm the following: When using Teton Order Routing with the Denali Data Feed, is the DTC Protocol Server (port 11099) fully enabled by default? Can I receive real-time data from Market Depth (DOM), Time & Sales (Tape), and volume, and export it via the DTC Protocol to external tools on my local system? Are there any restrictions, limitations, or licensing conditions that would prevent me from accessing or exporting these data streams if I use a live account connected through Teton? I intend to work with real-time institutional data through Sierra Chart in a professional environment, and I want to ensure that this setup allows full access and data integration from day one. Thank you very much for your support. Kind regards, Antonio |
| [2025-05-08 12:43:21] |
| Sierra_Chart Engineering - Posts: 25483 |
When using Teton Order Routing with the Denali Data Feed, is the DTC Protocol Server (port 11099) fully enabled by default? Yes but there are restrictions on its use. Can I receive real-time data from Market Depth (DOM), Time & Sales (Tape), and volume, and export it via the DTC Protocol to external tools on my local system? No you cannot. Refer to:Data and Trading Communications (DTC) Protocol Server: Restrictions Are there any restrictions, limitations, or licensing conditions that would prevent me from accessing or exporting these data streams if I use a live account connected through Teton? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
