Date/Time: Sun, 12 May 2024 03:42:18 +0000
Chartbook Setting
View Count: 1055
[2014-09-30 17:56:00] |
GCAdmin - Posts: 35 |
I am running version 1187. I will upgrade tonight after I am done trading. I am wondering if there is a way to have a specific chart in a chartbook be the one that you see on the screen when you open that chart book. For example I have a chart book with several forex pair charts in it. I want the 15 minutes charts for all these pairs to be the only charts that I see when I open that chart book. I have tried setting my chart book up like this and then saving it, but each time I open it is not saved the way I want to see it. Is this an option and if so how would I go about making it work? Thanks!
[2014-09-30 19:13:52] |
The chart window which is active at the time 18 Chartbook is saved will be the one that is active when the Chartbook is opened. There should not be a problem with this. It may not work this way if the chart is detached from the main window though. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
