Date/Time: Wed, 25 Nov 2026 21:56:01 +0000
Differents edge zones depending on the time.
View Count: 880
| [2025-05-03 17:04:34] |
| User818692 - Posts: 3 |
Hello on a 1H graph, I would like to be able to draw the edges area of different colors depending on the time of day. For example, that the edge zones of the Asian session are white, those of London yellow,... I tried to do this with charts that limit the period and plot it in the main chart (price/study overlay) but the line extensions in this case doesn't stop. A little help would be welcome, a big thank you |
| [2025-05-05 15:21:45] |
We are not sure exactly what you are looking for in terms of "draw the edges area". We think you may be wanting the "Date-Time Line" study, which lets you put a line at specific time. You can use multiple copies of the study and color each line subgraph as you want. Refer to the following: Date-Time Line Chart Studies: Subgraphs Tab >> Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-06 05:43:21] |
https://www.sierrachart.com/image.php?Image=1746509836369.png (edge zone: volume at price treshold v2 --> ask volume bid volume diagonal différence) during the US session, I would like the edge zone to be white, UK --> pink, ASIA yellow. |
| [2025-05-08 05:17:46] |
please help
| [2025-05-09 16:58:55] |
We are still not understanding what exactly you are wanting. Are you referring to the extension lines for the Volume at Price Threshold Alert V2? If so, then are these both the Red and Green lines in your chart, and how did you get the two different colors for these? Note that there is no methodology for coloring the extension lines different colors other than the one setting in the study itself for those lines. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
