Date/Time: Wed, 25 Nov 2026 21:56:04 +0000
[Programming Help] - Allow Study to Change Bar Period
View Count: 1128
| [2025-05-02 21:25:32] |
| User139065 - Posts: 24 |
Is the ability to allow a study to change the time frame of a chart still available? I can not find the option within Chart Settings |
| [2025-05-03 04:54:34] |
| Tony - Posts: 738 |
Are you talking about writing your own study with ACSIL? If so this is the one you will be using: BarPeriod.IntradayChartBarPeriodParameter1
| [2025-05-03 12:52:15] |
Yes, i was using the "BarPeriod.IntradayChartBarPeriodParameter1", but the the chart was not changing. ACSIL Interface Members - Functions: sc.SetBarPeriodParameters() I was able to figure it out, and now the code changes the chart bar period. There used to be a option in the chart settings that needed to be enabled to allow a study to changed the chart. I guess it was removed. |
