Date/Time: Wed, 25 Nov 2026 21:55:58 +0000
Order Timed out waiting for a response
View Count: 605
| [2025-05-02 01:16:22] |
| User421654 - Posts: 1 |
hope image is attached. orders not being filled. brackets show. no change in pnl or Rithmic trader dashboard.
| Attachment Deleted. |
| [2025-05-02 13:29:43] |
| User431178 - Posts: 910 |
You are connected to Rithmic but the symbology does not look correct for Rithmic. MNQ-202506-CME-USD is not Rithmic, should be MNQM5.CME. Edit Menu: Edit >> Translate Symbols To Current Service |
| [2025-05-02 14:16:22] |
| Sierra_Chart Engineering - Posts: 25483 |
Yes actually that is the problem. You are not using the correct symbols. Let us know if you need more help. The documentation linked to in post #2 is correct. If you manually need to change symbol of a chart, follow the instructions here: Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
