Date/Time: Wed, 25 Nov 2026 21:55:59 +0000
Drawings across linked charts not accurate.
View Count: 657
[2025-05-01 23:38:23]
lmahonefutures - Posts: 12
I'm having a slight issue after syncing charts where this trendline drawing isn't showing accurately. The top is the 4 hour chart and the bottom is the one hour. They are both set to Continuous Futures Contract - Date Rule Rollover, Back-Adjusted. If a trendline is drawn shouldn't they show up in the exact same level?
imageScreenshot 2025-05-01 183417.png / V - Attached On 2025-05-01 23:34:30 UTC - Size: 1.18 MB - 432 views
[2025-05-02 03:49:20]
Refer to:
Lines/Rays or Other Chart Drawings Move After Drawing Them
This explains, why you can see this. It is all perfectly normal.
Also refer to:
Lines/Rays or Other Chart Drawings Move After Drawing Them: How Chart Drawings Are Mapped Between Bars with Different Starting Date-Times
Date Time Of Last Edit: 2025-05-02 03:49:53
[2025-05-02 13:25:53]
User431178 - Posts: 910
Also doesn't help that OP, despite what is written, is comparing Back-Adjusted [CB] vs. Non Back Adjusted [C].
