Date/Time: Wed, 25 Nov 2026 21:55:56 +0000
Quotes for CFE products not updating in quoteboard
View Count: 658
| [2025-05-01 15:13:56] |
| user_xyz - Posts: 529 |
Last week or so VIX_CGI, VVIX_CGI, SKEW_CGI etc in the quoteboard have not been populating Daily Change / % etc.
| [2025-05-01 17:57:46] |
You should not have a problem for VIX_CGI and VVIX_CGI. But the SKEW appears to only update daily, so there is no current price to compare against the previous day, which is why you will not see a Daily Change for this product. If you are still having an issue with VIX_CGI and/or VVIX_CGI, then please get us an image of what you are seeing in your Quote Board. Refer to the following for how to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-01 18:22:22] |
See attached. SPX_CGI as well.
Private File |
