Date/Time: Wed, 25 Nov 2026 22:08:16 +0000
SC V SLOW
View Count: 582
[2025-04-30 07:51:50]
User110225 - Posts: 29
Good Morning.
I hope you are all well.
Over the past 2 days or so, my SC has been taking a long time make small changes that normally occur within a second or 2 after clicking the mouse button.
An example of this is when I do the following. Chart>Chart settings> Profit/Loss Format List
Any changes I make, for example changing this from do not display to another other option, takes approx. 2 mins, during which time the charts freezes. The circle is spinning and the chart that I made the changes for is saying not responding. After 2 mins the changes are made and the chart becomes active again.
The same also occurs when I make any changes to any of my charts, i.e. the colour of the VWAP line for example.
I have checked my computer and all seems to be ok, I am also on the latest version of SC.
I was wondering if there is anything you could suggest to help with this.
Best wishes and have a great day
Chris
[2025-04-30 14:36:06]
The one thing we will recommend is to use OpenGL if it is supported for your system and if you are not already using it. Refer to the following:
Graphics Settings: Use OpenGL for Chart Graphics
Otherwise, everything else to check/do is covered in the documentation at the following link:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
