Date/Time: Wed, 25 Nov 2026 21:55:58 +0000
MNQ only two digits showing or one digit
View Count: 992
| [2025-04-29 22:36:54] |
| Topdog33 - Posts: 44 |
Hi John, good afternoon so basically I don’t see more than two digit orders in the bid and ask column. I don’t know why I changed it to 2500 milisec but I still don’t see it. I see people trading on YouTube and the numbers are insane. There’s like 801,000 and mine is only showing the highest two levels two digits. Also, how do I set up the Delta on the very left-hand side where it shows the difference between the buyers and the sellers there’s for example -300 +200 blue and red. and I’m using Optimus with their data feed, which is iron beam
Date Time Of Last Edit: 2025-04-29 22:41:15
| [2025-04-30 14:26:49] |
For the MNQ, the Market Depth typically is 1 or 2 digits per price level. This is normal. Attached is an image of what we see at 09:24 Central US time for MNQ. We have no idea where 801000 comes from - that is definitely NOT a market depth value for the MNQ - that is what would be seen for a crypto currency. We are not certain of what you are looking for in terms of the Delta, but it sounds like you would want to setup a Volume by Price study that displays the delta values. Refer to the following: Volume By Price Study -- As a reminder - deactivate any exchanges that you do not need TODAY. Otherwise you will be billed again for them tomorrow, and we do not give refunds for exchange fees, as those fees go to the exchanges themselves, and they do not give refunds. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-01 13:26:09] |
Thank you, John the 801000 was a typo, but I’m signed up with Optimus. I’m using iron beam Teton so I don’t need any of the Sierra chart feeds correct like the Denali I can cancel those? Kindly advise so I may cancel it today. Thank you.
| [2025-05-01 14:18:50] |
Private File |
| [2025-05-01 14:19:35] |
That is the Delta looking for on the left where it shows negative red and blue boxes so the difference between the buyer contracts and the seller contracts
| [2025-05-01 14:30:41] |
You do need the data from our Denali Exchange Data Feed, but you do not need all the exchanges that you had active. We see that you have adjusted your selections, so you should be fine now. With regards to the delta values, that is a Volume by Price profile with the Delta showing. The information for how to use the Volume by Price study is at the following link: Volume By Price Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-01 22:12:03] |
Thank you, brother. I appreciate it.
| [2025-05-04 17:40:35] |
Hi John, so I don’t know where to find this I clicked on the link that you sent me, but I can’t add the Delta. The instructions are very vague and I don’t understand how to add it and I can’t find videos on YouTube to show me how to do it would you kindly assist?
| [2025-05-04 20:49:34] |
Hi John, so I got the Delta on there but I don’t see the negative in numbers. I just see the Delta bars but I don’t see the -200 +300 for example.
Private File |
| [2025-05-04 21:50:57] |
Instead of sending me the links, can you please just maybe in like two steps give me direction on how to do it. I look at all that stuff I get lost. Or where I need to look at under the menu because there’s a lot of things I don’t know which one it is.
| [2025-05-04 22:18:59] |
| Sierra_Chart Engineering - Posts: 25483 |
Do you want to see the difference between Ask volume and Bid Volume at each price level?
| [2025-05-05 15:57:26] |
You are not displaying the Delta volumes. You are displaying the total volumes. Refer to the following Input: Volume By Price Study: Display Volume in Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
