Date/Time: Wed, 25 Nov 2026 21:55:58 +0000
Using a different data source than primary, for equity options only
View Count: 1086
| [2025-04-29 08:12:34] |
| bozo_j - Posts: 51 |
Hi guys, I am using Denali data + Interactive Brokers trading service for futures trading. After some learning curve it all works very good. Now I would like to be able to trade IB equity options using Sierra, but the data source would need to be Interactive Brokers. At the same time, in another chart/chartbook I would still like to be able to trade futures via IB+Denali, as before. Is this possible? Right now if I add for example SPY-OPT-20250430-522.0-P--100-USD (SPY put option) to a Quote board and link it to DOM, it works fine. BUT both DOM and the chart are saying "Symbol settings not found for the current service" and so chart does not show any trade history for this option. So: 1. How to tell Sierra to use Interactive Brokers data for these symbols (equity options) only, and not Denali (which should be used for the rest)? 2. How to solve the issue above with the missing settings for this symbol? If you have an example of an equity option configuration that goes into Global Symbol settings that would help a lot. Thank you! Date Time Of Last Edit: 2025-04-29 09:27:50
| [2025-04-29 14:14:34] |
1. There is nothing special you need to do. Entering the symbol using the Interactive Brokers specific symbology will get you the Interactive Brokers data for that symbol. 2. There is nothing special you need to do. You can ignore the message about the symbol settings, it will go away after about a minute. We are not sure what you mean by "so chart does not show any trade history for this option". Are you not getting historical data? If so, then you would need to check with Interactive Brokers on whether they are supplying the historical data. Also, check the setting for "Global Settings >> Data/Trade Service Settings >> Main Settings >> Maximum Historical Intraday Days to Download Limit" and make sure this is set to the value for which you want the historical data to be downloaded. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-29 15:18:34] |
Yeah, you are right, data display is working, it just takes a long time for IB to send the historical data to be shown in the chart and I have to modify the symbol, which creates some important issues. Walkthrough: I bought an option in IB TWS first to make sure the symbol is correct, and I see SPY-OPT-20250430-533.0-P--100-USD in the Trade Positions. This did not work to load data in the DOM/chart and I had to add the SMART into the symbol as per IB options symbol format, so the symbol was modified to SPY-OPT-20250430-533.0-P-SMART-100-USD After a while it all loaded fine. So far so good. Then I sold the option in IB TWS to have a clear playing field, went to Sierra and bought the same option. It worked, order shows and executes in IB TWS. But here is where I experienced several problems and I think they all have the same cause - mismatch of the modified symbol for the option (with SMART added) and the one IB TWS is sending back to Sierra. 1. My P/L position in the DOM and Trading window just disappeared maybe after a few seconds of entering it, before which it showed the correct position and P/L amounts. 2. Sierra still sees the open position (with the symbol SPY-OPT-20250430-533.0-P--100-USD), but it does not show this position in the DOM/trading window/chart. 3. I tried to add SPY-OPT-20250430-533.0-P--100-USD as a Trade and Quote symbol in the DOM/chart, but no luck, DOM/chart do not show the position and P/L. UPDATE: I have seen Sierra using also SPY-OPT-20250430-547-P-SAPPHIRE-100-USD for this same option (when I created the option buy order in Sierra and observed the Trade Positions entry). Notice that here the strike price does not have .0 in the price, and that the exchange is not SMART but SAPPHIRE. None of these combinations (of strike price format and exchange name) showed me position and P/L after I entered them as a Trade and Quote symbol for the option - while at the same time the history and realtime data for this option works fine. This is obviously not your problem but problem with IB, but do you have any idea how to elegantly solve this mismatch between the symbol you get from IB (shown in Trade Positions) and the symbol I have to use in order to get the data from IB (with SMART exchange part added manually) and for the position (before it disappears) to show in DOM/chart, as I think this is the root cause of the issues? Thank you for your patient assistance! Date Time Of Last Edit: 2025-05-02 06:18:07
| [2025-05-02 12:12:28] |
Dear John, Just a ping about this IB options position/PL issue, above. Thanks! |
| [2025-05-05 19:44:39] |
| Sierra_Chart Engineering - Posts: 25483 |
We apologize for the delay. This was a long posting. We needed time to review. In cases like this we recommend using the order fill calculated position: Trading Information Windows: Using Order Fill Calculated Positions In Special Cases Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-07 16:09:26] |
Dear John, no problem about the delay. Everything is working now as expected. I have configured a separate DOM for equity options with the settings you mentioned, and it works well. Thanks for the superb assistance, again! |
| [2025-05-08 11:04:25] |
And for people in the future trying to trade futures options via Interactive Brokers + Sierra combination, you have to update the symbol in Sierra for these to work. e.g. IB symbol for MES put will be shown as: MES-FOP-20250508-5685.0-P--5-USD but for it to actually work in Sierra and show the option data and position in the DOM you need to add the exchange to the symbol and remove the decimal place from the strike price, e.g.: MES-FOP-20250508-5685-P-CME-5-USD Or, another example for a full ES contract futures option: ES-FOP-20250509-5685-P-CME-50-USD Notice, it takes up to 1-2 minutes for the data for the option to load in the chart. Anyhow, maybe this will help somebody. Date Time Of Last Edit: 2025-05-08 11:33:05
