Date/Time: Wed, 25 Nov 2026 22:08:09 +0000
Data, set up issue
View Count: 641
| [2025-04-28 20:56:44] |
| User654138 - Posts: 39 |
I am reinstalling on a new machine, maybe I'm missing something obvious or maybe I screwed up installation. I am not able to download nymex delayed and I thought I had subscribed to rt futures package including nymex. Additionally I am trying to connect to stage5 or dorman with the teton option which I can't get to work either. |
| [2025-04-29 13:58:15] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
