Date/Time: Wed, 25 Nov 2026 22:08:01 +0000
How to remove the lines between the sessions volume?
View Count: 742
| [2025-04-26 22:20:50] |
| AndreiFA - Posts: 2 |
Hello, I use Session VP. But i con't figure out how to remove the lines between the sessions volume. (photo attached to this message) Can you help me? Date Time Of Last Edit: 2025-04-26 22:21:27
| [2025-04-28 15:31:10] |
Set that particular item's subgraph (for instance, "Value Area High" and "Value Area Low") Draw Style to be "Dash" instead of "Line". Refer to the following: Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
