Date/Time: Wed, 25 Nov 2026 22:08:02 +0000
Hiding crosshairs on mouse move out of the chart
View Count: 858
| [2025-04-26 13:36:28] |
| bozo_j - Posts: 51 |
Hi guys, there is a small annoying visual issue that I would kindly request if you can add to your TODO list. When crosshairs is enabled on a chart, and you move the mouse out of it, the crosshairs remains visible on that chart. Since I have DOM on the right of the chart I regularly manage to place the crosshairs exactly over the rightmost candle of the chart, and at that point I can no longer see the wicks of the (most important at the time) candlestick, as the crosshairs is above it. Can you make the crosshairs invisible after the mouse is out of the chart area? So, exactly the same behaviour as on TradingView when it comes to crosshairs. Thank you and kind regards! |
| [2025-04-28 14:59:01] |
You can do this already. Refer to the following setting: Chart Drawing Tools: Hide Chart Values Tool when Pointer not Over Chart (Tool Settings >> Chart Values >> Chart Values) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-28 16:46:15] |
Fantastic, thanks a lot!
