Date/Time: Wed, 25 Nov 2026 22:08:05 +0000
SIM ou REEl
View Count: 728
| [2025-04-25 06:51:27] |
| User914407 - Posts: 65 |
Bonjour, Comment faire pour créer un petit affichage pour savoir si on est en SIM ou en REEL ? Je voudrais un affichage "SIM" en vert quand je suis en SIM et "REEL" en rouge quand je suis en REEL. Merci |
| [2025-04-25 14:08:49] |
From Google Translate: Hello,
How can I create a small display to show whether I'm using SIM or REAL? I'd like the display to be "SIM" in green when I'm using SIM and "REAL" in red when I'm using REAL. Thank you. To begin with, refer to the following for the various ways to know if you are in Simulation mode or not: Overview of Trading: How to Know You Are in Trade Simulation Mode There is also a study called "Trade Menu Status" that exposes the state of "Trade Simulation Mode On", along with a couple of other items. You can then use that information to create some kind of display/notification for the state of that option. Refer to the following: Trade Menu Status For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-26 17:33:13] |
Je ne comprends pas ce que fait cette studie (Trade Menu Status)
| [2025-04-28 15:21:10] |
The "Trade Menu Status" exposes the state of the following menu items: - Trade >> Trade Simulation Mode On - Trade >> Trading Locked - Trade >> Chart Trade Mode On You can use this to have some kind of display to note when Trade Simulation Mode is either On or Off. For instance, you can use the "Text Display For Study" and set "Use Text for Non-Zero Value" to "Yes" and then enter the text you want for when "Trade Simulation Mode On" is enabled in the "Non Zero Value Text" field. You can then use the "Spreadsheet Formula" to give you a value of 1 when the opposite situation applies and then use another "Text Display for Study" based on that "Spreadsheet Formula". Attached is a Study Collection that does this. Refer to the following for how to use this: Study Collections: Using a Study Collection Provided by Sierra Chart Support For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
