Date/Time: Wed, 25 Nov 2026 16:39:11 +0000
Control bar button request
View Count: 799
| [2025-04-24 21:02:13] |
| User273277 - Posts: 145 |
Quick request: having a control bar button to open a configuration window for "Order Allocation to Trade Accounts". It is time consuming to go to the order window, Menu, Settings, Order Allocation to Trade Accounts, then change the config. Having multiple personal and prop accounts often means doing this time sensitive series of clicks multiple times a day. |
| [2025-04-24 21:37:18] |
We have set this as a Feature Request. Just so you are aware, you can save the "Order Allocation to Trade Accounts" as part of the "Trade Configurations". This would allow you to setup specific configurations with specific order allocation rules. Refer to the following: Order Allocation to Trade Accounts: Order Allocation to Trade Accounts Include in Save Trade Window Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-24 23:02:23] |
| Sierra_Chart Engineering - Posts: 25481 |
We will add this.
| [2025-04-24 23:29:08] |
We will add this
Yes! Your team is awesome. |
| [2025-07-08 14:54:32] |
This has been added. Update Sierra Chart if you have not already.
| [2025-07-08 19:01:04] |
Thank you. I have added the "OrderAlloc TradeAcc" button to my toolbar and it's already saved me time today. |
