Date/Time: Wed, 25 Nov 2026 22:08:12 +0000
Moving chart around manually with fixed scale.
View Count: 660
| [2025-04-24 19:44:10] |
| cuckiecheese - Posts: 119 |
In tradingview, if you set the scale to manual, you can drag the chart around anywhere. Is it possible to do that with a fixed scale and the hand tool in SC? Thanks |
| [2025-04-24 19:48:43] |
You can have a fixed scale and move the chart with the Hand tool. We feel that we are missing something in this question, as you can easily try this and see if it works, so there is no need to post this as a question. If you are asking something deeper, then give more information on what you are trying to do and what you are having a problem accomplishing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-26 13:57:07] |
When the chart is in fixed scale, I am limited to dragging the chart horizontally, but am not able to move the chart around vertically
| [2025-04-28 15:01:19] |
Make sure you have the following set to "Yes": Chart Drawing Tools: Support Vertical Scaling/Movement With Hand Tool (Global Settings >> Tool Settings >> General >> Tool Options) If the above is already set to "Yes", then we need to understand what you mean by "fixed scale". What scale mode or option are you referencing in this case? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-28 16:50:33] |
excellent! that is exactly what i needed, thank you!
