Date/Time: Sat, 11 May 2024 04:56:43 +0000
Count Down Timer with Renko Tick Chart
View Count: 1429
[2014-09-29 11:50:11] |
djcurcio - Posts: 236 |
How can I have the count down timer count down the time in the current Renko bar? I'm trying to see the elapsed time of the bar. Thanks |
[2014-09-29 13:48:22] |
Use the Countdown Timer study. We are not sure what problem you are having.
[2014-09-29 15:53:06] |
User84094 - Posts: 43 |
I think you want Bar Time Duration ? |
[2014-09-29 18:28:50] |
Yes, we see now what you want. Use the Bar Time Duration study.
