Date/Time: Tue, 17 Nov 2026 18:08:41 +0000
Data
View Count: 682
[2025-04-24 11:09:58]
Robert Wojczak - Posts: 178
I signed up and paid for the nasdaq data feed for equities but is is showing delayed
[2025-04-24 14:49:32]
John - SC Support - Posts: 48555
Make sure you enter the symbol with the -NQTV suffix (such as META-NQTV). The -NQTV specifies that you are wanting data from our NASDAQ TotalView exchange.
If you do not use that suffix (such as META) then the data comes from our "U.S. Equities Consolidated Tape" exchange instead. Since you do not have that exchange active, you would get the delayed streaming data.
[2025-04-24 14:57:06]
Thank You
[2025-04-25 11:07:11]
Im doing the above and its still showing delayed
[2025-04-25 14:19:39]
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
