Date/Time: Wed, 25 Nov 2026 22:08:19 +0000
AMP Futures Micro CL (MCL)
View Count: 776
| [2025-04-24 05:02:14] |
| Dan the Man - Posts: 111 |
Hi, Can I live trade AMP Futures Micro CL (MCL) using SC data in the Data/Trade Service Settings? If so, what are the setup steps? Regards |
| [2025-04-24 05:19:25] |
| Marski - Posts: 25 |
open Flie > Data/Trade Service Settings > Main Setings > go to Current Selcted Service (List) > must be > Teton CME Routing (trading) > and then go to > Clearing Firm List > must be > AMP and then applay all. ready
| [2025-04-24 14:40:29] |
The selection of "SC Data" in the "Current Selected Service" means that you are only connected to our Sierra Chart servers to get data. We are not a broker, so we do not have trading capabilities. You state that you have AMP as your broker. What order routing service are you setup to use with them? It will be one of either Rithmic, CQG, or Teton. Once we know this, we can point you to the proper instructions. What Marski posted is the simplified instructions if you are setup for Teton. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-24 14:59:00] |
| Sierra_Chart Engineering - Posts: 25483 |
Can I live trade AMP Futures Micro CL (MCL) using SC data in the Data/Trade Service Settings? If so, what are the setup steps? You cannot do it this way.You need to set Sierra Chart to Teton Order routing assuming your account with Amp is on Teton order routing. Instructions: Sierra Chart Teton Futures Order Routing: Setup Instructions And then open a chart following the instructions here using the Teton order routing symbol for MCL.: Getting Started, Opening Charts and Basic Trading: Open A Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
