Date/Time: Mon, 13 May 2024 06:17:57 +0000
Timescale is confused
View Count: 1143
[2014-09-29 09:54:24] |
User82828 - Posts: 44 |
For the fdax my timescale is confused. As you can see (yellow arrow in the picture) today I have a 9 o'clock between two 8 o'clock at the time scale (x-axis). here you can also see the chart with German time: http://screencast.com/t/YJYnbp59XO8 All former days including monday from the weeks ago are ok and don't have this disorder in the timescale. I use the Iqfeed datafeed but another coleague which uses exact the same software has'nt this problem today. Date Time Of Last Edit: 2014-09-29 10:28:40
[2014-09-29 14:01:47] |
We do not need to see all of these settings. Timestamp errors are not unusual with IQ Feed. Re-download the data from before the timestamp error by following the instructions in help topic 2.1.2 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails2.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-29 17:52:22
[2014-09-29 16:17:28] |
"delete and re-download the data" solved the problem
