Date/Time: Wed, 25 Nov 2026 22:08:18 +0000
Account Reminder
View Count: 653
| [2025-04-23 15:56:57] |
| JohnnyD - Posts: 4 |
Good morning, I can no longer replay charts for past 1 month. I have SP 11. Kindly advise. Thank you, J. |
| [2025-04-23 19:10:36] |
What exactly is the issue? What is occurring when you try to replay a chart?
| [2025-04-24 11:38:39] |
When I try to replay chart from April 22, I see 1 bar of data from March 25. I'm using SP 11. Any help would be appreciated. Pls see attached. |
| Attachment Deleted. |
| [2025-04-24 14:52:53] |
You have the date for the start time set as "2024-04-22", therefore you are trying to start the replay from approximately 1 year ago. You therefore need to have that data already loaded in the chart in order to replay it. The system will not automatically load older data due to a replay - you need to have it setup beforehand and then perform the replay. Also, in this case, since you are trying to get data from 1 year ago for a futures contract, you will need to setup that chart as a Continuous Futures Contract. Refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-24 16:54:13] |
Thank you.
