Date/Time: Mon, 13 May 2024 19:45:27 +0000
looking for a indicator.
View Count: 849
[2014-09-28 22:20:02] |
User48557 - Posts: 138 |
Is there a indicator that can draw a horizontal line at a specific time everyday and stop 24 hours later and repeat? For example 8:30 am Central time on a 60 minute chart I would like a new line created everyday.
[2014-09-28 22:25:42] |
mkata - Posts: 103 |
Use "Horizontal Line at Time".
[2014-09-28 23:03:03] |
Yup that worked. Problem solved
[2014-09-28 23:04:39] |
Use Horizontal Line at Time: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s306 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
