Date/Time: Wed, 25 Nov 2026 21:56:11 +0000
P/L and NPL at zero
View Count: 1037
| [2025-04-21 16:28:32] |
| User714901 - Posts: 12 |
Hi there. When I take a trade on my account (Sim 1), by clicking on buy /sell market, P/L and NPL stays at zero in the trade window. The trade lines come up ok on the chart, and also show on my DOM. Going to trade - Trade orders, shows order filled, and attached orders open. If I click on flatten, the trade lines disappear from the chart, the trade service log appears, saying Unable to flatten/ Reverse, Position does not exist. What am I doing wrong? Regards |
| [2025-04-21 18:20:06] |
Our first guess is that you are not opening a position. When you place the order, it is not a Market order, but is a limit or Stop-Limit of some kind, therefore there is no open position at that point. And when you Flatten/Cancel you are doing this before the parent order fills, so you were never in an open position to flatten. But you are seeing attached orders showing and those are removed with the Flatten and Cancel command. Check the Order Type you are entering on the Trade Window and make sure it is for the type you want and at the price point you want. Another possibility is that you may be looking at a different Trade Window that has a different trading account selected. In other words, you are actually trading Sim2 (for example) and not Sim1, but the Trade Window you are viewing is for Sim1. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-21 19:45:26] |
I have market order selected, Sim 1 account is in the drop down in the trade window, Trade service log does say Trade Account Sim 1 where it says unable to flatten. I don't think I have a sim 2 account. However, I updated the instance to latest edition, and things are working now as they should. Thanks John Date Time Of Last Edit: 2025-04-21 19:45:51
| [2025-04-22 05:53:35] |
| Sierra_Chart Engineering - Posts: 25483 |
At the time you have the problem what is the query count on the Trade >> Trade Activity Log: Trade Activity Log: Trade Activity Not Displaying or Clearing (Improving Trade Activity Query Performance) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-22 07:31:17] |
Here is better documentation related to our prior question: Trade Activity Log: Determining Current Query Count Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-05-08 05:46:40] |
Hi John, apologies for the late reply. This issue is happening again, so I checked the Current query count. It's at 134. I should clear this I presume? Regards |
| [2025-05-08 13:52:29] |
That is a very high query count. You will need to delete trade activity files in order to improve performance. Refer to: Trade Activity Log: Trade Activity Not Displaying or Clearing (Improving Trade Activity Query Performance) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
