Date/Time: Wed, 25 Nov 2026 22:08:04 +0000
[User Discussion] - Trade Copier
View Count: 967
| [2025-04-21 13:11:59] |
| coachted - Posts: 545 |
Can I use a rithmic account for data?
| [2025-04-21 15:54:28] |
The title of this thread is "Trade Copier" but the question is not related to that title. So we are not certain of the real question being asked. If you are asking if you can get data from Rithmic into Sierra Chart, the answer is "Yes". Just be aware that Rithmic data has a lack of historical data available, and we do not give any support for issues with Rithmic data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-21 18:25:25] |
sorry John....my bad i was googling trade copiers....but since i can use rithmic data I have another question...if i have rithmic data account and also have a topstep account which uses rithmic would the trade copier then work or since they have different login info and passwords it wouldnt work...
| [2025-04-21 19:21:59] |
Our trade copier (Order Allocation To Trade Accounts) only works with accounts that are accessible under a single login. Those accounts will then all be available in that connection. Refer to the following: Order Allocation to Trade Accounts There is at least one third-party that makes a copier for Sierra Chart that allows for copying between accounts with different logins. You would need to search for this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
