Date/Time: Sun, 12 May 2024 19:01:48 +0000
[User Discussion] - BHCS_BAR_HAS_CLOSED
View Count: 1081
[2014-09-28 11:47:48] |
Hendrixon - Posts: 130 |
I'm trying to time exactly how long a bar took to build and need to know when exactly this code will get executed: if (sc.GetBarHasClosedStatus(sc.Index) == BHCS_BAR_HAS_CLOSED)
I'm asking this cause there are situations when there are time gaps between last bar close and next/new bar open.{ //code that gets current system time } For example using 100 Ticks bar periodicity: * When last bar counted the 100th tick [point A], its done... even though sc.Index still haven't advanced by +1. * Next bar won't actually start forming right away, since SC needs to receive a new tick for that to happen. [we have a time gap] * New Tick received so new bar starts forming. sc.Index gets advanced by +1. [point B] Will the above statement execute at [point A] or [point B]? Date Time Of Last Edit: 2014-09-28 12:46:37
[2014-09-28 14:01:57] |
B
