Date/Time: Thu, 20 Aug 2026 00:37:14 +0000
SC icon missing
View Count: 1225
| [2014-09-28 06:08:56] |
| tobi - Posts: 351 |
I've used the attached icon to start SC for a very long time. This is no longer available. Why is that? Could we please have it back. Thanks, tobi |
| [2014-09-28 06:45:42] |
This has been removed, but you can always have Windows reference the icon from any other file. You should be able to reference it from a bitmap file. Since you have the icon, save it as a bitmap.
