Date/Time: Wed, 25 Nov 2026 22:20:54 +0000
studies (question about Numbers Bars)
View Count: 663
| [2025-04-11 15:52:47] |
| userfifty3 - Posts: 8 |
Hi, is it possible to highlight in numbers bars chart secound biggest, third biggest volume after maximum volume (point of control) in every candle? and is it possible to highlight minimum volume in numbers bars chart in every candle? Thank you for your help. |
| [2025-04-11 16:38:52] |
| Sierra_Chart Engineering - Posts: 25484 |
No this is not supported regarding the first question. For the second question yes you can highlight minimum values: Numbers Bars: Highlight Minimum Value In Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
