Date/Time: Mon, 13 May 2024 05:30:18 +0000
How to Un-check "Draw Volume Profile" from Short cut menu
View Count: 899
[2014-09-27 22:06:39] |
User76939 - Posts: 11 |
1. After I draw a market profile and tried to edit it, When I left-clicked on a chart, another market profile will be drawn from the new place I click. I notice that the "Draw Volume Profile" item was checked all the time. Is there anyway to un-check "Draw Volume Profile"? 2. How to import a chart book file (.cht)? 3. How to import a study file (.cpp)? 4. How to add the item "Erase All Lines" to the Shortcut menu (when I Right-click a chart), which is not available from the item list to add? Thanks. Weijun |
[2014-09-28 19:53:30] |
1. Select Tools >> Pointer. 2. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#CopyChartbook 3. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html 4. Global Settings >> Customize Chart Shortcut Menu . And then Add: Erase All Non-text Drawings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-28 19:53:54
