Date/Time: Tue, 17 Nov 2026 18:08:50 +0000
Delayed Data - Shouldn't Be Delayed
View Count: 759
| [2025-04-10 20:39:38] |
| User969241 - Posts: 155 |
I am getting the 'delayed' feed on the top of my chart. All of my packages are paid up to date. Why is this not live?
Attachment Deleted. |
| [2025-04-11 07:57:52] |
| User135243 - Posts: 334 |
you've a verfied Live-account?
| [2025-04-11 11:39:29] |
| Sierra_Chart Engineering - Posts: 25432 |
Your computer's clock may not be set accurately. Refer to: Prices / Data Falling Behind: 4.11 - Incorrect Determination of Data Delay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-11 13:06:17] |
My computer timezone is correct and there isn't a countdown timer.
| [2025-04-11 14:56:58] |
It is not about the time zone, but your computer's clock. Make sure it is set accurately: Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-04-11 16:56:51] |
NTP settings are correct and the timezone settings are correct.
| [2025-04-11 17:09:41] |
How much of a delay are you seeing? We see what looks like a two minute delay from the chart image. Is that actually what it is?
| [2025-04-11 18:41:02] |
Yes. It looks like a 2min delay is correct. 2minutes from my computers time.
| [2025-04-11 18:42:36] |
If that is really what it is and the computer's clock is accurate, then you have very poor bandwidth with your Internet connection. This is unusual to see that kind of a delay. Usually that is something that would be seen like on a satellite connection. Also refer to: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-04-11 18:43:49
| [2025-04-11 19:04:54] |
I have very fast internet. I tried the 'sync now' in windows and I think it worked. I will respond if there is an issue.
